The electrical wires for the bow Nav light pass through a hole in the deck with "goo" of some sort to caulk the hole.
The system seems like a hokey one but then again, it has lasted since 1983. I am wanting to replace the cable (insulation has cracked off) and the deck pass through is leaking a little when taking waves on the nose or heavy rain.
Have any of you solved this on your boat. Lots of hardware for through-deck installs but the pass-through seems to be too close to other stuff to fit something there. I was going to go with the "goo" route. If you have done this repair, do you have a recommended goo?
