Has anyone had to remove the steel bar between the liner and the hull that the chainplate rod screws into.I will be stepping the mast in the fall and would like to do a full inspection of my chainplate system - deck side re-bedding etc. etc...It seems that this steel bar can not be readily inspected or replaced if necessary and to make it out of plain steel is puzzling me why?How big is that steel bar under the liner and how would you inspect it or replace it if necessary??Can you slide it out to an area forward or aft through a cutout??
