Den Drown
We've had a problem with our anchor light on the mast-head. It would work fine and then after an hour or so, it would short out (pop the breaker). If we reset the breaker at that point, it would pop again. If we waited for an hour or so, we could run it again for an hour before it would pop.Sounds like a short that only happens when the wire heats up, right?We removed the anchor light. It wasn't in great shape, and I was hoping that the problem would be there. However, there is still a 400 ohm continuity between the positive lamp wires and the mast. So I think the short is still there.Here's the problem. Normally, I'd want to replace the wires, but I can't get to them. There is a green wire coming off the breaker panel, but it's white at the mast light (actually it's two white positive wires with a black negative). There is no access to the mast wires that I can find. We've checked under the port-side cabin light that should be under where the wires pass between the mast and the breaker panel, but we can't find green or white wires there.Suggestions on how to replace these wires or otherwise get at the short? Thanks,Den DrownHunter 34 Sailboat "Kojos'a"kojosxa@pobox.com
