John K Kudera
The final fit of our A/C unit involved the installation of the Mermaid device that sucks the condensate from the drip tray.I mounted the unit on the new foreward bulkhead, according to the instructions,made the connections for the water in and out,allowing some slack so the unit can be unbolted and pulled out for service if needed. The electric box fits under the chart table in what was the small storage area. I fit all the wires to it then screwed the mount to the bulkhead.A tight fit, but its all in there.Ducts are run thru the new bulkhead, the bulkhead into the area behind the setee cushions,one aft one foreward in the main cabin,up thru the storage bins and exiting on the shelf above.A second duct was run into the aft cabin.I would have hoped for a fourth outlet, however, there simply is no space for it.(4 1/16th inch holes are large!)as are the 4 inch hoses and y pipes.To install this unit under the chart table, is a tight fit, all excess wood needs to be removed,but you retain the chart table, (and wine rack?)If you are thinking of AC, E-mail me if you have a question.John Kuderas/v Fifty/Fifty
