John K Kudera
OK, OK, Joe and Ed Convinced Me, I bought a three way valve at West Marine. Installed same in the intake line near the front of the engine box. After the strainer,My boat has a small opening plate in this location, and I placed the valve so as I could reach it from this opening.I ran a hose from the three way valve, and mounted the 110 volt raw water pump to the rear of the engine box, so as to be able to service it from the aft cabin hatch that is over the drive shaft and stuffing box. I ran the hose and wire from there to the A/C under the Chart table,using the same route that my other wires run. I bought the 20 amp circut breaker at West and installed it in my stock Hunter panel. I mounted the thermostat in the same spot as the switch panel, towards the bow, easily read, out of the sunlight away from the outlet vents. works for us? I ran the out flow thru hull under the chart table, just on top of the "step"in the inner hull. A hole of about 4 inches needs to be drilled in the inner hull liner so as to allow a proper sized backer to the thru hull fitting.I am about 10 inches from the waterline, but this could not be helped. At this point I have the base built, painted, installed, and have the a/c placed on the base for final fit.The water is run to and from the a/c,I have the electric run to the control box, and the wire from the pump and thermostat run as required. I ran one air supply duct to the foreward port side of the salon, ran thru the area behind the back rest cushions, then up thru the storage to the top shelf, where it exits into a vent. A second vent will be in the aft cabin, and one in the a/c cabinet. The fourth step will be in building the cabinet, adding air return vents, and final fastening down and testing. My friend who just completed his installation,says his is loud, but he says there are some adjustments he has not yet tried. Will keep advised, Ideas anyone? Please post.
