Does anyone know the prop shaft length and taper for a Hunter 33 (1982)? I am thinking of replacing my bronze/brass shaft with SS when I install a PSS shaft seal.
I found a PDF with the Hunter Shaft and Prop sizes. This says the shaft should be 1"x49" and the prop at 14"x12. The 3 blade prop on her now is a 15"Austral (not sure of the pitch). A bit more than what is specified.
