I recently measured the prebend and rake in my 336 mast. Per some other posts on this board, I think the mast is way off. The prebend seems to be about 6", which is not too bad....however the rake is about 24".
I proceeded to loosen all the shrouds and then started tightening down the forestay (which has furlex installed). The rake of the mast hardly moved. So I eventually took the nut on the forestay adjustment as far down as it would go. It moved down about 3". I tightened back the shrouds as needed to get proper tension with loos gauge.
The result...I only moved the rake forward about 3".
What to do???? Any suggestions would be welcome.
