Anyone had this problem on their H33? (Hull #208 Yanmar 3YM30) The plastic Syphon Breaker is located between the Heatex and the Mixing elbow and is fitted with a clear overflow hose which goes into the pan. It started slowly with just a few drops during initial running and then stopped. It is now a steady stream and the last time out I ended up with around a litre of water in he pan. Before I pull it off and have a look (for perhaps a sticking valve) does anyone know the inner workings or has encountered and solved the problem.
