Terry Arnold
Relating to the H33, I have a question about the structural arrangement of the shrouds. Load is transferred from shroud to chainplate which then goes through the deck, reappearing in the cabin with several bolts fastening it to what appears to be wooden structural members. However, upon closer examination, the teak trim pieces only overlay a kind of plywood sandwich and the plywood pieces inside the sandwich don't appear to be attached structurally to the hull. Has any H33 owners had this assembly apart? It seems that there must be a steel component glassed structurally into the hull to transfer the shroud loads. My boat shows no distress, I just want to know how all that load is transferred. Also, at the base of the mast compression post, it disappears into a small fiberglas box which in turn rests on the bottom of the bilge. Anybody had to do work on this compression post? I have drilled into the fiberglas box and it seems to be solid fiberglas without any wood at all. My boat is a 79 and lately I notice that the lee shrouds are not as tight as they were a year ago when I got the boat.
