Jim Logan
THere was a string a while back about replacing the rudder shaft packing on H33's. My recollection was that it is possible to replace this packing in the water (with the boat at the dock and no waves)if you can get the compression nuts off. Is this the way it works, or do I have to pull the boat out of the water?
