G
Guest
I have a Hunter 33. The jib lines come through outblocks which are attached to the toerail. I have two blocks on each side. When on different points of sail, the line has to be changed from outside to inside the stansion. This is a real pain. Has anyone used two lines per side?? Do you always leave them inside or outside??? Did you add on a track ????? I'm confused!! Otherwise the boat sails well and is easy to single-hand. Any suggestions would be appreciated!
