H31 shaft diameter and stern tube diameter
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
May need to replace the dripless shaft seal and both are necessary to order proper part.
Aug 16, 2009
1,000
Thanks, Fast. I was at the boat and measured. However, to order the correct dripless kit, I also need to knew the shaft tube size, and I couldn't measure that with the boot on. I followed the instructions given in another post and actually managed to reduce, though not eliminate the leakage, down to a half cup a day. As this is a potentially catastrophic part, I will replace at haul out, which is now on the critical to do list.
