H31 running rig
47
Question. On my recently aquired 84 31 there are 2 deck organizers with 2 spots each. I have running through them 1 Jib hal, 2 main hal, 3 main sheet. So have you guys then added more to be able to have acess to reefs from the cockpit? do you have outhaul on winch to cockpit as well? do i then need to add another set and blocks at the mast base for reefing? Dave
Daryl
Several Options
The cleanest way is to add an identical set of organizers on top of the original set. You'll need to do minor grinding on the sea hood to accomodate higher lines. Then you'll need more sheet stoppers. I left my outhaul on the boom but I did have four halyards, vang, reef and a line to the foot of the cruising spinnaker
Dec 2, 2003
4,245
- - Seabeck WA
Dave,
I was going to call you R2D2 or 3CPO, or something like that. :) But then I saw your name. What does your other 'name' stand for? As far as your boat goes, drive it for awhile. See what works for you and make any changes that you want. Following this logic, I ended up with eleven stoppers on my cabin top on my H34.
Dec 23, 2003
268
Hunter H31 83-87 Captain's Cove Bridgeport, CT
I added more
On the port side: jib halyard, topping lift, small reef jiffy On the starboard side: main sheet, main halyard, large jiffy reef
