Yep, Same problem...
I've had the same problem on my H31 over the years. Initially, water draining from the anchor locker, through a hose in the forward part of the V-berth, was the main culprit. I replaced and re-caulked the fitting in the bottom of the anchor well, replaced the hose, and re-configured the thru-hull drain. The original thru-hull fitting was kind of mickey mouse, so I got a threaded elbow that could be caulked on the outside and tightened on the inside, and that seemed to work. There were some recent posts concerning this issue on another Hunter model.BUT... occasionally it's still damp after a rainstorm on the starboard side of the forward end of the V-berth, and I'll try the earlier suggestions regarding the toe rail and the bow pulpit. A towel (ridiculous, I know) stuffed into the space beneath the anchor well seemed to absorb the residual moisture, so I was thinking it was still seeping through the anchor well somehow, but now I think that Steve's suggestion and Tim's suggestion are next on my list. Chandler's suggestion is excellent, but I don't have a leaf blower, and I'm not sure how I could pressurize the boat with it if I did. And let's all hope that Don's hypothesis is incorrect; those two words... 'compression post'... give me the friggin' heebie jeebies.Regarding the aft berth, I've got evidence of moisture on the inside of the transom, instead of the port wall. So far, I have not been able to identify it's source, and any ideas will certainly be appreciated.Good luck - Rick
