H31 - Hot Water tank installation
May 25, 2015
5
Hunter 31 Toronto
Our 1984 H31, new to us, has a leak in the hot water tank. It is an Isotherm tank.
It is mounted with all connections aft and jammed up to a cross member. There is easy access to the tank from the galley. I plan on rotating the tank so that the connections are easy to get to.
Just wondering if anyone else has done this or sees a problem.
Feb 6, 2013
437
Hunter 31 Deale, MD
My water heater is a Seaward with the connection on the forward side. Makes sense.
