H31 Halyard
G
gr8_2_av8
I know it has been asked but I can't find the archive I need the length and recomended dia for a forstay halyard H31. Also for those of you who hank on do you raise the head sail so as to not rub the bow pulpit? ie add a section of wire with loops to the tack? Dave
Dec 2, 1999
15,184
7/16" line.
If you are going to get pre-made halyards, then I would suggest that you go with their standard length which is usually about 110' x 7/16". This works for the jib & main halyards. I have all of the sizes but cannot find them right now.
DreamBoat
Check the chandlery
here on HunterOwners.com. They have a running rigging calculator for your boat.
Aug 13, 2005
23
Hunter 31_83-87 Ventura, CA
Running rigging
Main Halyard 7x16" by 106' Jib Halyard 7/16" by 106' Main Sheet 3/8" by 60' Jib Sheets 7/16" by 90' Main Traveler 1/4" by 40' Topping Lift 1/4" by 16' Reefing Line 3/8" by 40'
