H31 Halyard Replacement
Bob Rutland
I need some advice on how to change the main halyard on my 84 H31. How did you "fish" in the new halyard? How mutch line do I need to buy?
Dec 2, 1999
15,184
Just did it.
Bob: I just finished doing this. My approach was as follows: First I wanted to keep the original screw type head shackle. I cut it off and sent it to my line supplier. They spliced it into the new line. For the jib halyards I ordered new snap shackles with the line. I ordered 7/16" jib halyard made from solid color Sta-set. I ordered 1/2" Sta-set X for the main halyard. All of the halyards are 110' long. This may be little long but much better than short. When I wanted to re-feed the lines I sewed the bitter ends (end to end) of the lines together with waxed whipping twine and then wrapped them with rigging tape. Just feed them through carefully like you are raising your sails and it is done. The jib halyard is on an upper and a lower sheave. The upper one is the port and the lower is the starboard. There was a little friction going over the top on the lower (starboard) but no big deal. If I was doing again (and I'm not going to). I may consider going with a 7/16" main halyard from Sta-set line instead of the Sta-set X. The "x" has less streach but is quite a bit stiffer. I think that the Sta-set line and the smaller diameter will cause less friction and make hauling the main sail a bit easier. I would also recommend that you color code the lines as much as possible. This makes sailing with guests much easier. Most of them do not have a clue what a sheet, halyard, rope, line and maybe even a boat is. So being that most humans are visual, color coding makes giving instructions much easier. My color scheme is Port jib halyard is Solid Red, Starboard is solid Green. The main sheets ( traveler) is solid Blue. The main halyard is white with a Blue tracer. Still have a couple to replace but not doing anything else until I get my new Jib furler. So lets make this easier Port Jib Halyard 7/16" x 110' Starboard Jib Halyard 7/16" x 110' Main Halyard 1/2" x 110' Hope this helps.
M. Kraus
Halyrd replacement ADD
Steve Dion's response is correct in all respects. you might want to consider a knot on your halyard shackle instead of a splice. You will be able to get a full lift in your sail without the risk of the splice tail binding in the sheeve. Also, you can rotate your halyards end for end without losing any length.
Mac Lindsay
Bob: Have just replaced both main and jib halyards. They are origional size of 7/16 inch and the length is 105ft. I used duct tape to tape a 100ft long 1/4in line to the old and new halyards to pull them through. Tape around the rope afew times overlapping to a distance of 6in either side of the join. You can thread them together before taping if you wish. I had no problems pulling them through. I re spliced the shackles my self and if you haven't done that before, buy Brian Toss's book on splicing and knots. It's fun learning centurys old skills and quite rewarding to have done it yourself. regards, Mac Lindsay sv Kitkatla,1984 H31
