H31 forestay diameter
John Blakelyh
Does anyone know the headstay diameter? Mine is incased in an old roller furling and I cannot get callipers on it to measure it. Will be ordering a roller furling later and need correct size.
okiman
Oct 1, 2005
77
Hunter Cherubini 33_77-83 Okinawa, Japan
Forestay Measurement
If you are going to replace the furler right away, you can run a halyard or two from the top of the mast to the bow to replace the forestay. Disassemble the furler drum so you can measure the current stay. Otherwise, you can have someone hoist you up the mast and take a measurement at the top of the furler donut where the stay connects to the mast. Because the furler stresses and loads up the forestay, I would recommend you go one size larger than the current forestay. You choice, just a little added insurance for a few more dollars. Good luck.........
Dec 2, 1999
15,184
check out the fitting.
John: Check out the fitting that is swedged onto the forstay. It should have a number on it. The number is the size in 32nds.
