H31 cockpit drain fittings replacement source?
boz86
Sep 30, 2012
29
Hunter 31 Pasco County, FL
Hi,
I have a leaking cockpit drain fitting. Previous owner(s) have tried silicone around the fitting but that's not working anymore and isn't a good long term fix anyway.
Anyone got a good idea where to get one? Here's a picture on the inside.
thanks,
Ken
Hunter 34 Alameda CA
Ken,
Disassemble the entire thing first and inspect for breakage. That includes unscrewing that white nut and pulling the fitting up through the cockpit deck. I think it is just a regular thruhull fitting if it needs replacing. The gray piece is a standard female ell connector. If nothing is broken or stripped then clean out all the silcone and rebed the throughhull from the top with some butyl tape or Boat Life caulk. Wrap some teflon tape on the last few threads after snugging up the nut and reinstall the female ell.
Hope this helps.
Allan
Dec 2, 1999
15,184
I assume that the PO tried to apply silicone on the top of the fitting. I would also recommend that you remove the fittings, inspect and replace and/or rebed. Use a proper bedding material.
We replaced ours with a flush unit with a screen.
boz86
Sep 30, 2012
29
Ken,
Allan
Pretty old and worn, so I replaced with a We$t Marine version. This one is more translucent so I get a little sunlight as a bonus in the aft cavern.
One project down, hundreds to go...
