Backstay Adjuster
I have the spilt backstay as well (with adjuster) and I find it does help when going up wind to put extra pressure on the backstay. The mast has a lot of prebend built in (mine is at 4.5") but I can get the mast back another few inches (I've checked it by hanging a plumb bob from the main halyard and then tensioning the backstay and measuring the difference)it does straighten out the forestay sag and gives the genoa a better shape - especially in upwind slop. Now to make a difference I have an 8:1 split tackle on mine with which I can put a lot of tension in the rig. My mast step is solid and my rig is tuned as per B & R instructions. The later model B & R Hunter rigs where a somewhat different setup (outer shrouds attached at the outside of the hull, fractional rig, etc., which sets up a whole different level of geometry in the rig requirements) and to say the backstay on this model of Hunter (masthead rig, narrower sheeting angles, bigger head sails, etc.) is redundent is non sense - ask these guys who say it's redundent if they would remove the backstay AND then go out and sail? I can garantee they probably wouldn't! If you race the boat put an adjustable backstay setup on, even if it doesen't make a huge difference it will make you feel like you've done something, if you cruise don't spend the money.Mike
