H30t Boot Stripe
Apr 28, 2021
1
Hunter Hunter 30_88-94 Hampton
Any early 90's H30 owners know if the boot stripe is vinyl or painted? I need to remove mine to raise the waterline and would like to know what I'm getting into before I haul out.
May 27, 2004
2,039
It is painted or black dyed gel coat... Not a decal.
If you prep the old stripe properly with sanding, barrier coats and primer,
your bottom paint will cover the old black stripe nicely and permanently.
Likes: ATMurphy
Dec 18, 2012
159
Hunter 37.5 Annapolis
I had an H30G. I did the same. I took the bottom paint to the top of the boot stripe, and added a new boot stipe above. I also renamed the boat. My boot stripe was gel coat. The majority of the work was masking the new boot stripe so that it was straight and slightly tapered - Lasers were involved!
Paul
