I'm trying to determine the mast height from waterline on a 2005 H306 with a furling main sail. I found the owner's manual on line, and now I'm even more confused. Page 36A has a sketch of a standard sail plan boat which shows a mast height of 40.25 ft (from determined waterline). Page 36B has a sketch of an optional furling sail plan boat which shows a mast height of 44.25 ft (from determined waterline). Seems pretty clear...right? But hold on...
On the very next page, page 37, there is a Dimensions, Capacities, Etc list that documents the mast height (from waterline) as 42' 6". This is different from both sketches. Also, is there a difference between "determined waterline" terminology and "waterline"?The sketches use "determined water line" and the dimensions, capacities, etc list uses "waterline". It seems to me that the dimensions sheet should at least match one sketch or the other, right? So why doesn't it? Uggggh!
Why is this so important to me, you may ask? Well, I have a 43' bridge to get under just outside my marina. I'm interested in pursuing purchase of a 2005 Hunter 306 with a furling main sail. I need to know it will clear the bridge, and we are talking inches here. Thanks.
