A
A.J.Wortelboer
Help! I think I need to change the motor mounts on my vessel. The shaft as it exits the hull is now rubbing on the lower side of the opening. I discovered this after haul out this fall. The strut and the cutlass bearing appear to be fine, and the coupling to the shaft and tranny is ok. The whole engine has seemed to drop down. The mounts seem to be the only thing that could cause this type of problem. Has anybody had this happen to them? How much of a job is it to change the mounts and is there a better aftermarket set of mounts I could use. The single lunger has much viberation but I did not notice it to be more than normal, but how do you tell from day to day season to season use. Is there sombody that has had experience with this?I got all winter to think about this and would like to get all the information together for my spring project.
