H30 Holding Tank?
L
LJ Bryd
Where would you install a holding tank on this boat? Overboard and Deck pump-out fittings are already there by the head, but no tank. How big can the tank be?
Bill Mathis
Holding Tank_Same Here
I have the same question. Do you think the holding tank would fit in the storage area under the port side of the V-berth?
Peggie Hall/Head Mistress
How far is it from the head to v-berth?
If the head is in the aft end of the cabin, it's prob'ly too long a hose run from the head to a tank under the v-berth, but if it's not longer than a 6-8' run, that's the ideal place for it. There are several articles in the Head Mistress forum Reference Library (on the forum homepage) that should help you figure out how to plumb it, and what size tank you need for your boat and use.
