Have to agree.
I found out about the mast step thru bolts a few weeks ago when I had the mast pulled in preparation for installing a tabernackle rig. With all the rigging freed the crane operator started pulling up the mast but it would not come off the mast step - frozen solid. No amount of rapping with a hammer or rocking the mast from side to would get it broken loose. All that was happening is the deck was lifting off the compression post. This was good because it gave access to the nuts (1/4-20 lock nuts), but unfortunately the bolts were spinning in the base since we didn't have access to the bolt heads. Finally wound up cutting the bolts with a hack saw. Needless to say, a tedious process.
One thing I did learn from this is that the deck area under the mast is really strong. The nuts just had little flat washers on them, not great big fender washers, and these only made small dents in the headliner even though the crane basically lifted the boat out of the water about 2". Had the deck been weak or not sound, the nuts and small washers would have just sucked right through it. I was pleased that this didn't happen.
