Water heater must be equipped with heat exchanger
The heat exchanger is a coil inside the water heater through which hot water/coolant from the engine circulates to heat the water in the tank. There's a diagram of it in the water heater manual on the Raritan website at www.raritaneng.com...they're all alike, so when you've seen one, you've seen 'em all. The bad news is, unlike a heating element or anode--which are replaceable, a heat exchanger cannot be retrofitted or replaced. You'll have to replace the water heater to get this handy little option.However, marine water heaters are very well insulated and will hold water hot for 24 hours or longer. So my suggestion is, raise the thermostat so that you have VERY hot water--thus using less, and making it last longer.
