H290 Spinner setup
9
Hunter 290 Hamilton ontario
H290 Spinnaker setup
I have the hunter 290 and have an asymetrical spinnaker to use this year. I was wondering if anyone has placed the bottom block on the anchor roller and if they had any problems with it.
2,362
my friend place the tack line on the his h280 anchor roller wheel on account his doesn't have a hole on the anchor roller bracket to fit a block, whereas i've a block on my h326 roller bracket for the tack line. i guess it should be as far forward as you can make it.
Sep 4, 2009
9
Did you re-enforce the anchor bracket and if not do you see any problems with gel coat cracking???
Oct 29, 2005
2,362
The hole where I place the block at roller bracker is slightly thicker (reinforced). It came stock like that. I don't see any cracks on gelcoat.
