I need help in finding a fuel tank to replace my old plastic tank.
I have been finding fuel in the bilge. Looks to be coming under liner and then entering bilge at the keel bolt. I traced the fuel lines and can not find a leak from them. After setting for a week, I removed about 16 ounces from bilge. Of the 16 ounces, only 4 onces was water. I have the bilge pump turn off. I have drained the fuel from tank and next is to remove.
Before draining the tank, I ran the engine and it runs good and found no leaks at the fuel lines. The previous owner did have a fuel filter leak and replaced housing. Could the fuel I keep pulling from the bilge be from fuel trapped under the liner that is slowly finding its way to the bilge?
