Follow-Up to base note
OK, Traced out the entire exhaust system from stern discharge to water/ exhaust mixer, and the "U" pipe. No sign of obstruction. Used one of those plumbers spiral snakes. Nothing but bits of carbon.Remove flex hoses from 'baffled?' muffler (round, about 14" inches long, just above bilge) .. looked real clean. Didn't remove as some of the mounting screws appeared to fasten through the hull.Remove "U" hose from water mixer jacket to water / exhaust mixer. Clean as is the interior of the two ports.The only 'apparent' obstruction "may be" in the exhaust of the water mixer, which is clearly rusted bad enough to the rubberized water exhaust hose could not be renmoved without chancing destruction of same. Checked the 'exhaust' with screw driver tips and handles, andfound a 1" handel could be inserted about 1/4" into the outlet of the water mixer after scraping a bit of rust off the outlet port.Questions on the 'zinc' came up. no answer yet.This is the Yanmar SB8 single cyliner, type X cooling. Water comes from the pump, to a "T" in the head. Part of the water is diverted through the head and part can flow through a continuing hose to the water jacket. Water jacket is that piece on the rear of the engine that the water / mixer screws into.// Yes, did replace and reaffix everything otherwise disconnected // ;^)It has been described to me that the water flow shoild be like from a slow hose in spurts. It's doing that alright, but now with the water on, it 'hunts' up and down in RPM. Found that out Sunday coming into the mooring field, into a 10 kt wind wondering if the engine was going to slow down and to 0 rpm .. at least the anchor would still work .. i think ;^)I am wondering abot the water pump, and it's effects if it were not pumping enough volume, or if portions of the impeller blades did break off, where might they be now ?? However, if I recall my practical physics classm if the impeller blades were not making a good contact with the pump housing, then only negligible water would be pumped ?? Also, when the water is left off a few moments, and then turned back on, there is a time delay of about a minute, more/less before the engine slows down, implying "filling the system". The smoke is decidedlty whiter and more volume with the water on. like embarresingly bigger clouds ... ThanksBob
