h27 Steering Cable Replacement
139
Hunter 340 Burlington, Ontario, Canada
I'm in the process of replacing the steering cable on our 1981 Hunter 27.
I've removed the old (and frayed:eek:) one but before I go about getting a replacement length of cable to attach to the chain, I'm just wondering if the cable needs to be of a specific type? It appears to be 3/16" in diameter, twisted strands now....
Direction / particulars appreciated.
Feb 4, 2007
81
- - Somerset,
Steering cable
There are two ways to due it. You can call EDSON in New Bedford, Ma and order exact replacement parts.
www.edsonmarine.com
You could take the cables to a rigger and he could duplicate them for you. I replaced mine with a local rigging shop and the difference in price between the rigging shop and EDSON was negligable. Just make sure you get SS wire. Good luck.
Dec 27, 2004
139
Re: Steering cable
Ok thanks...I suspected stainless steel but don't know if there are different strengths etc. Good idea re a rigging shop - I'll start there.
Sep 26, 2008
44
Hunter 27 Port Washington
You might not have a Edson. Your boat might have a Yacht Specialties Pedestal. Possibly the cable is the same, but you should be sure of what make pedestal you actually have installed on the boat.
G
g meyer
h27 steering cable
My 1982 Hunter 27 has a Merriman pedestal. I installed a replacement
cable and chain unit from Edson several years ago. It fit perfectly.
gm, savannah
