h27 leaky port windows and hatches
5
Hunter 27 Marina Del Rey
my 1979 h27 has developed leaks in every window, port window, and hatch. I've avoided the issue but now that the exterior restoration is complete its time to get going on the interior; which will have to start with the leaks. Can anyone offer advice on where to begin? I expect the forward port hatches will best be replaced, but the windows present a more interesting challenge as I have no idea how to replace them if I find I need to.
Jun 2, 2004
5,802
There are several photo projects in the 'Hunter Owner Mods' forum under the 'Boat Info' tab that deal with replacement. You can check my own in the H37C projects. But maybe it is just a matter of replacing the rubber gaskets. Those are available here in the SBO store I think.
OK, since you are new here how about some links. Remember that all the Cherubinis have/had similar portlight installations.
http://hunter.sailboatowners.com/index.php?option=com_kb&Itemid=267&cat_id=28&aid=7378&page=article&mn=33_77-83
http://hunter.sailboatowners.com/index.php?option=com_kb&Itemid=267&cat_id=38&aid=7383&page=article&mn=37-cutter
http://hunter.sailboatowners.com/index.php?option=com_kb&Itemid=267&cat_id=38&aid=7206&page=article&mn=37-cutter
http://hunter.sailboatowners.com/in...&cat_id=38&aid=6887&page=article&mn=37-cutter
Jun 21, 2007
2,118
Below is a cut-and-paste of a post I made several years ago on this topic for the ports. This pertains to ports that have leaks due to old/compressed gaskets between the clear plexiglass and the port frames. Subsequently I have done the same to my hatches as well. We have had three moderately good rain storms in the San Francisco area so far this year. My ports and hatches still aren't leaking one bit.
Here's the previous post:
Maybe Apply New Gasket Material Over Old?
The port gaskets on my 1980 Hunter were leaking when I bought the boat 1.5 years ago. An inexpensive fix stopped the leaking and the fix looks like it will last. The plexiglass window ports on my boat are the type that swing open to the inside, hinging at the top. The original gaskets on the frame had become hard and compressed. What I did was:
- The original gaskets are affixed inside a channel all around the perimeter of the port frame against the which the plexiglass is dogged tight against. I left the old gaskets in the channel, but with a razor-sharp box cutter knife, I shaved these original gaskets flush with the outside of the channel.
- I then wiped the shaved original gaskets with lacquer thinner to clean off any dirt/grime/soap/wax and to "reactivate" the hard foam.
- Finally I applied a high quality stick-on gasket tape made by MD directly on top of the old shaved/cleaned gasket. (MD gasket tape is available at all hardware stores. This is the smooth surface foam type -- not the porous foam stuff. It comes in a double band, and is hollow in the inside. The two sides neatly split when the two sides are pulled apart. Comes in brown and white colors.) Make sure that the two ends of the new gasket tape around the perimeter meet on the top side. Don't stretch out the stick-on gasket as it is applied.
This solution might be worth a look-see for your situation. However suggest that you do only one port first to check if it works .... before doing the others.
jotruk
Oct 8, 2008
18
Hunter 27 Lake Whitney
I have a hunter 27 that developed leaks at the opening windows I went to the New Found metals site and bought windows there. I had to do some cuttine on the forward windows but very little I am going to replace the non opening windows in the salon after the first of the year and again they will be new found metal windows
