260 THROTTLE CREEPDoes anyone know if the late model 260 pedestal steering by Edson has a throttle tension screw inside the pedestal? Hate to tear it apart if it doesn't have one!
I revisited this issue because I believe the 260 pedestal is specific to the 260 and I hadn’t seen anything about it.Thanks for the answer. I put a C70 on a special mount on top of the pedestal that makes opening it up a bit of a trick. I also have a WP32 so inside the pedestal I have a spaghetti nest of wire to work around.
