I have a H260 with a water issue. Last season we had quite a bit of water in the bilge after a road trip. Since then we have sealed the compression post (as that has shown up on this forum as the most probable cause) and took care of another transom crack. Last week after a particularly rough sail, we had water in the bilge again. I think the holding tank may be cracked.
I'm thinking of removing the holding tank and replacing it with a soft water bag style holding tank. Has anyone done this before with a H260 sized boat?
I'm concerned that the only way to remove the existing tank is to cut it into pieces as the hatch access is too small to remove the tank in one piece.
Any suggestions?
Any suggestions?
