Dave Miller
I have a 2001 H260. Stored the boat with antifrezze in the water system about 3 gallons - circulated through the plumbing before buttoning her up for winter.This spring, I took her out of storage and pumped the antifrezze out of the tank - no problem.Filled the tank with fresh water and the faucets all pumped fine until the water level in the tank dropped below the vent tube (about 1.5 inches from the top) to the tank then they quit pumping water.Filled the tank again and the faucets worked until the water level was below the vent tube (1.5 inches from the top).So, I tried sticking a hose through the fill opening to drain the water out of basically a siphon but couldn't get the hose all the way into the tank. So for the heck of it I filled the tank again leaving the siphone hose in and when the take was full, water came shooting out the overfill vent on the port side of the bow. It was odd, because when I filled the tank without the siphon hose in, water never came out of the overfill vent. Further, the faucets would now pump again and emptied the tank several inches below the vent tube (4 inches from top) but then they quit pumping as before. I repeated this procedure - siphon hose, fill, pump to 4 inches from top and quit pumping.So I don't know what is causing the problem but I am not able to pump out the entire tank. One final symptom, when I open the cap to the tank afer I have pumped and it has quit, it is always under pressure. I don't know if that is normal or not.If you can help I would appreciate it.Dave
