H260 water balllast valve gasket...
225
- - Boston
Hi all, What is the typical lifespan of the gasket on the ballast tank valve? What material is recommended for replacing it and is there a recommended adhesive? Thank you! Tom
G
George
Valve Gasket
Several people have used rubber from a wet suit. Drop by a scuba shop. I'd use a very thin coating of 3M5200. That being said, most valves leak and I don't see how that makes any difference in how the boat sails - why bother?
Jul 19, 2007
156
Hunter 26 Brookville Indiana
True George.
Not gonna get any more or less water in the balast tank, so if it leaks a little, so what.
