H260 running rigging into cockpit
6
Hunter 260 Buford, GA
Hello all, I'd like to run more lines from the mast into the cockpit so I need to attach more blocks to the mast step. There are pins that stick up through the mast step to which the blocks are attached. Does anyone know what these pins are called and where can I buy some?
Jun 2, 2004
252
hunter 260 Ruedi Res.
which mast do you have?
mine is a charleston spar and it has 6 blocks built into the base of the mast.
Jun 14, 2004
11
- - Bakersfield, CA
Hunter can help
I have done what you have discribed for the outhaul, topping lift and reefing lines because I didn't like the cam cleats within the boom. The factory sold me additional blocks that have the vertical post (pin) attachment. Worked out nicely with real cleats mounted right before the hatch. I called Hunter with the original block description and received what I wanted by UPS in a week or so.
C
crazy dave
blocks
advise which mast you have and I will give you the correct contact person. What are you trying to do? Spinnaker?
A
Allan Lansche
Thanks for the responses
Guys, thanks for the responses. Ed, I'm going do do exactly what you described. Topping lift, reefing lines, maybe vang. I'll contact Hunter.
