Ok guys,
Mast on the H260 up for the first time in over a year! Yeah! I do have a question. I'm running the jib halyard through the port fairlead, then back a friction block, then to the portside cleat. We've noticed that this imparts a HUGE amount of side tension on the mast. My "fix" is to run another line from the forward part of the mast base (theres a metal loop there) starboard just like the jib halyard. This helps, but not completely.
Some other info. I've got a Charleston Spar mast and all lines come out at the base of the mast ( blocks for three on each side). The jib halyard comes out the aft port block.
Ok...is the tension normal, or am I rigging the thing wrong?
Deucer
Deucer
