H260 Emergency Tiller
1,446
Hunter H260 Traverse City
It occurred to me that I've never tried the emergency tiller on the H260. It appears that the little ears don't give much leverage to steer with. I assume most similar small boats have something similar.   Since I have the wheel I think a realistic test would require disconnecting the steering cable which I don't want to do. Maybe I have to come up with a device to attach to the little ears to give more leverage? Has any 260 owner tried to steer with the emergency tiller and how hard is it?
Jul 17, 2005
586
Hunter 37.5 Bainbridge Island - West of Seattle
Hmmm...there ought to be another part
I can't believe they expect you to steer with those little ears. The force of the water won't even let you turn it 1/100th of a degree. I expect there is another piece hidden somewhere on the boat. Or maybe the PO has it, or lost it. Something that will connect onto this piece (with ears) and has a long handle on it. If you can't find it, you may be able to fashion some out of a metal pipe fitting and a pipe.
Ross
Tiller
George; Did you try connecting the emergency tiller pipe below the stern rail? That's how I connect mine. The pipe has a much lower angle (better steering leverage) and the forward end of the pipe just clears aft of the wheel. Good Luck
Brett, Charlotte, NC
Hmmm...
I don't think the ears are for anything except maybe tying a rope or something to the tiller. The opposite end should have a hole in it to screw to the little bracket at the top of the rudder. No twisting should be neccessary. Unless I am a total goof.
Aug 11, 2006
1,446
Stupid is as stupid does...
Ross is right, went out today and hooked it up as he suggested and felt pretty stupid that I had not figured it out on my own....
Jun 14, 2004
174
Hunter 260 Portland, OR
Yeah but...
you were actually thinking a step ahead of all the rest of us. I had never given any thought to the emergency tiller, and the fact of the matter is - it's a whole lot better to understand its application now, then when it's dearly needed as the boat is wandering without steerage into an oncoming grain barge (common on our river). I thank you for giving us the idea to pull it out and understand its use. I think most readers would agree!
Reudi Ross
George
I checked mine before going to mexico and insalled a 1/4" bolt in the rear hole on the rudder bracket and stuck a 3/8" bolt thru the emergency tiller with a wing nut so I won't be looking for hardware and tools if and when I need it
