H26 wood floor removal
bmorr
Apr 5, 2009
82
Hunter 26 Pueblo Lake CO
I would like to remove wood floor to replace, but not sure how to proceed. Anyone pulled it to replace? How did you do it? Was it possible to pull intact to use as a pattern?
Sep 24, 2018
4,087
Catalina 30 MKIII Chicago
Spear it animal did a very nice replacement on their 60' Beneteau. Very challenging to do to that level of perfection. Take a look at their videos on it
Likes: bmorr
-na -NA Anywhere USA
There is a recessed area in the deck floor pan to accept a new teak and holly floor glued down with liquid nails. Make sure to use a trowel to spread the liquid nails. Cover floor and apply weights and let dry. Then apply a bead preferably Dow 795 between the new floor insert and main floor to keep water from getting underneath new teak and holly floor glued down
Be careful in removing old teak and holly floor with chisel not going into deck pan
