H26 Whisker Pole Needed
7
Hunter 26 Kingston, ON
I have a '94 H26 w/a 110 Genoa. Seeking a quality yet "economical" adjustable whisker pole or plans to make one. Residing in Kingston, Ontario (east end of L. Ontario, Thousand Islands region)....could even travel to upper or western NY.
gfroch
Jun 5, 2004
77
Catalina 30 Rochester, NY
Will you be using for a the jib or a spinnaker? Just for the jib, I saved a lot of money by getting one at West Marine suggested for a smaller boat. The jib is so small, I figured I'd take a chance. It's worked great, cost substantially less, is easier to stow, is very light. It's really no bigger than a large boat hook. I'm not sure of the size, but would guess it's the 6-12' telescoping.
good luck!
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
Adjustable pole
I also use the small adjustable whisker pole from West Marine:
Link to pole
I stow both my boat hook and whisker pole on the head bulkhead. I can pull them up from the cabin top.
May 30, 2012
7
Re: Adjustable pole
Thanks very much. Does your pole have clips at both ends or is one end a spike?
