H26 water from below
I just purchased a 1996 H26, thanks to this website. Everything has been quite astounding, except for the problem you mentioned. We had water in the side-berth compartments, & around the inspection hole across from the head. My first concern was the ballast tank.I phoned a technical rep with Hunters, & he informed me that it would be ok to seal off those storage compartments. I used a 4 inch piece of styrofoam & sylicone. As well, I recocked the area around the pipe (above the table), just below the base of the mast. Finally, we took off the hatch, & cleaned up that little piece of wood underneath the plexiglass. Last night we had a large downpour, & I haven't had a chance to see if my hard work paid off. However, after the last couple of days of sailing, it is clear the water is not from the ballast tank. Without the rain, everything remained dry. The rep also suggested that I place a small amount of food dye in the tank. That would allow me to see if it is rain water or ballast water. If anyone has some other suggestions on keeping these boats relatively waterproof, please let me know!Rick Engel
