Pat
I am in the "survey" process of a 1994 H26 with trailer.The Problem:Trailer has no visible VIN# or Rating Plate/Sticker.Why this is a problem:In PA, regulation of trailers with brakes is very strict and among other things will not be able to be registered or inspected (required) unless Title paperwork matches trailer info. At the moment there is no way to prove that this trailer is actually the one that the title is representing. Current title is in CA.The question:Have any of you dealt with this issue before? If so, how did you resolve? Also, where is this information on your trailer?It looks like this trailer had a sticker on the driver side of the tongue which is all but completely worn off and no dicernable info. can be read.What I've done so far:I've contacted Hunter Marine and asked if a replacement plate/sticker could be generated (answer is pending, but didn't seem favorable).I've contacted local registration outfit and they did confirm that a match would be necessary for inspection purposes and in the event I was stopped, etc... They further suggested that I leave the trailer titled and registered in CA (I could potentially do this since I have relatives there).Any input any of you may have that could help me here would be greatly appreciated. I want to get out and sail without the worry of bad registration / tile work! Thanking you in advance!-Pat
