Check the Archives
We've had this discussion before & the concensus strongly favoured crossing the shrouds. I followed this advice last year & seemed to have better luck, as already mentioned, with forestay tension. It also seemed to produce a better balance between the lower and cap shrouds. I keep approx. 500 lbs on the former & 600 on the latter. These numbers keep the mast relatively straight in light & heavy conditions. This is where the heavier wires on the Hunter 26 really seem to make a nice difference.By the way, when we were out last weekend, I had better luck in heavy wind gusts by adjusting the traveller instead of the mainsheet. Last year we installed a small traveller at the base of the hatch. By keeping the mailsail taut, and dropping the traveller during the gusts, we could avoid some of the extreme weather helm that seems to occur if the mainsheet is released & the sail twists out of shape. I think the same result (or close to it) might be achieved by really tightening up the vang during the gusts. I bought another block & tackle for the base of my vang so that the cleat opens upward instead of downward. That way, I could release it on the fly from the cockpit. I also added a heavy shackle below the bottom tackle. When sailing on a broad reach, I can then move the vang and use it as a preventer from the foot of the stantions. has anyone else had any luck with this arrangement? Rick
