F
Fred
I just towed my "new" H26 from Oregon to Gabriola Is, BC. I have never had a water ballast boat, although I've had a few trailer sailors and keel boats.I would appreciate any advice on trailering, motoring, rigging, and sailing the H26.Has anybody added a wood or propane heater? Where did you mount it?If you have a propane stove or heater, where do you put the tank?My boat has an Origo 2 burner alcohol stove. Are they hot enough to boil spaghetti water in a reasonable amount of time?I have a friend with an older McGregor 26 (the slower one) who motors without the water ballast in the boat. He does this with the mast up, but only in settled weather. Will the H26 fall on its side with the mast up and no water in the tank?Thanks. This is a great resource.
