dimentions
1 and 5/8ths exterrier diameter tube
87.5" from bottom to mast support
92.5" total hight
If I was redesigning one, I would think about making it expandable. Maybe an interior tube that slides inside and can be raised/extended after attaching the side stays, but is still the correct height for trailering etc. I have found the hardest part to raising the mast is the initial 3 to 4ft of lift. If you could raise it this much, thus changing the angle of the initial pull it would help dramatically. Don't forget the gin pole and the side cables stays that stop the mast from swaying side to side while raising. Hope this helps Chris
