I've had an on-going saga with my H26 centerboard bracket removal. The 3/4" CB bracket bolt would not come out. It would only free spin. I finally removed the bolt after a huge effort over a longer than needed period of time. Today, I lifted the boat at a boatyard in a Biloxi, MS recommended by Rick Webb (thanks Rick!). After wiggling the centerboard a little, the whole assembly came out........ in six pieces! As many of you predicted, the CB bracket welded nut was one of the pieces. The weld had broken. The next part that fell out was one of the side plates of the bracket. The complete weld along this plate completely broke. The only parts of the bracket that remained intact was the other side plate that is welded to the small top plate (the one the bolt is welded to). The other parts that fell out included the CB pivot pin, uphaul line roller, and the roller pin. All of the miscellaneous parts looked OK. The uphaul line was in fair shape. All of the welds that broke look fixable (I hope). There was not any apparent corrosion. Next steps: re-weld bracket and nut back together, inspect the other weld, replace CB uphaul line, prep and apply bottom paint, SPLASH!! THANK ALL OF YOU FOR YOUR HELP AND SUPPORT!!! BrianW
