H26.5 Marine head
41
Moody 346 Kenosha
Ok, at the risk of sounding stupid... :redface:
I am winterizing my new (to me) H26.5.
Trying to be diligent with the plumbing as:
1) I've never had a boat with plumbing and
2) I live in Wisconsin where the water starts getting hard about this time of year.
Anyway, the plumbing diagram shows, vents and intakes. But I can not find where I pump out the darn head! I am assuming the holding tank is underneath the head, right next to the fresh water fill line and fresh water holding tank (which have not been used since we bought the boat). Winterizing section says put in regular auto motive antifreeze... OK.
An anti-freeze & waste mix... :eek:
How do I get it OUT? :confused:
Thanks ahead (no pun intended) of time.
WW
-na -NA Anywhere USA
Usually a fixed holding tank will be vented and there should be in the aft mostly on the port side an opening filler for better lack of terms that should say waste. You will pump out the tank from there.
As for winterization, never use the toxic anti freeze used in vehicles. You will need to use RV non toxic antifreeze and I mean non toxic. I would pour it down the head and flush and then leave some of it in the holding tank after it has been pumped out.
Aug 27, 2013
41
Moody 346 Kenosha
Thanks for the prompt response. I'll look for that waste port.
Why non-toxic for the head? In part V page 1 of the owner's manual for winterization of the head, it specifially says "ethyleneglycol automotive antifreeze." Is there some way that the waste can get into the fresh water tank? If that's the case, to me, it's a lot bigger problem than the toxicity of coolant.
I'm still learning, so please inform!
regular anti freeze is very toxic and even a cap full of that will kill animals like your pet dog or cat. In addition it is not good for the environment and is very harmful. All states do not allow that into the waters. A good example back in the 80's in Hopewell, VA, a company threw that mess into the James River which the river from Richmond to the Chesapeake Bay was closed down to swimming, fishing both commercial and pleasure, water drawn for drinking and agriculture and so on which was international news.
In fact, one Boy Scout camp which allowed a staffer who did not have the experience to work on boats nor taught him the dangers and even allowed him to keep running the boat put antifreeze (toxic) into the boat which was loosing over a gallon a day into a lake continue as the camp director and program director allowed it. When the powers to be found out, the boat was pulled and all were admonished for it. In fact the state water control board found out but since the incident had been resolved quickly with the boat coming out, there was no action which I was able to resolve that.
So, I would use the non toxic RV antifreeze. Would you want to put your head into a bucket of water with traces of toxic anti freeze in it? Think about it.
crazy dave
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
all of the above is good advice.
I also live in a cold climate (Canada) and around here most sailors flush and pump the holding tank well just before the boat is hauled. Then disconnect the head water supply hose from the thru-hull and place it in a jug of rv-antifreeze pump the head to run it through the head and flush the hose going to the holding tank. In the spring just reconnect the hose and pump some fresh water through the head.
good luck, Bob
Jun 3, 2004
7
Hunter 26.5 OCONTO, WI
I believe the 26.5 came with a porta-pottie from the factory. Mine has a built-in water tank only and a porta-pottie for other plumbing needs.
Hope this helps.
Tim
Nov 8, 2010
11,386
That was common practice 25 years ago, when your boat was built.
Aug 27, 2013
41
Moody 346 Kenosha
Thanks to all of you that responded. I am seeking some additional hands-on-step-by-step help from the local yacht club.
One more question along this thread, if it isn't too involved.
Exactly what is the differences between a "marine head" a "porta potty?"
I get the idea behind the organic/compost bed.
Does anyone have strong opinions on each design? I'm looking down the road a few years when we go bigger for longer duration cruises.
And as usual, thanks ahead of time.
WW
Jun 3, 2004
7
A marine head is a fixed unit with bowl, separate holding tank and all associated piping and hoses attached to the boat. A porta-potty is a self contained unit with the bowl portion sitting on top of the holding tank, all clamped to the boat but removable.
I daysail mostly and overnight occasionally so I prefer the PP.
Its simple and easy to winterize but must be emptied manually.
Tim
Aug 27, 2013
41
Moody 346 Kenosha
Tim 22904,
Since you have a 26.5..
One: Do you know the volume of the holding tank? I can't find specs.
Two:
"...Its simple and easy to winterize but must be emptied manually..."
Define "manually."
Thanks.
7
I think the specs say 18 gal. for the freshwater tank but mine look more like 12 gal.
Manually means the bottom portion (waste tank) must be removed and emptied in your toilet. Its not as bad as it sound. Been doing this for two boat and 16 years.
VERY SIMPLE !
Tim
Aug 27, 2013
41
Moody 346 Kenosha
OK... Thoroughly confusing weekend... The yard was nice enough to fill the head & plumbing with non-tox antifreeze and close all the seacocks/petcocks. (I didn’t know they did this as part of the take out)
I’m pretty sure can’t be a “Porta Potty” because it is bolted in place, nothing resembling a tank underneath it, has a through hull (below the waterline) feeding it and it is completely hard plumbed in.
Anyone know if this was an option in 1988 H-26.5’s?
Thanks.
WW
Jul 27, 2013
298
Hunter 37.5 1065 Rock Hall, MD
I have also read of people using inexpsive vodka in the plumbing lines to prevent freeze damage. That way there is no issues about toxicity. I am a "new" 1990 legend 37.5 owner and I am planning on using Vodka.
Aug 27, 2013
41
Moody 346 Kenosha
On the other hand, my father always said, "If you mix your bourbon with water, you're ruining two perfectly good drinks..."
WW
Mar 26, 2011
3,720
Corsair F-24 MK I Deale, MD
regular anti freeze is very toxic and even a cap full of that will kill animals like your pet dog or cat. In addition it is not good for the environment and is very harmful....
crazy dave
This post is QUITE incorrect. Please, research before posting.
a. The reason for using automotive AF (ethylene glycol) in some heads is that RV AF (propylene glycol) is incompatible with the neoprene parts in some brands of marine heads. If the parts are neoprene, use EG or drain. The manufacture certainly researched this and was not wrong.
b. Pets and children do not drink black water. The black water should be pumped out to a POTW in most cases (pump-outs are generally required in inland waters and certainly for the OP's boat--no treatment system), where the EG is slightly more biodegradable than PG. Comments re. human and mammal toxicity are off topic and effects on POTW systems are incorrect.
c. Aquatic toxicity for both EG and PG are equal. Human toxicity after diluted into a river is clearly negligible, since glycols, like drinking alcohol (also toxic), it needs to be at material levels to be toxic. This is nothing like pesticides and heavy metals and discussing in that manner is unrevealing and incorrect. The example of a large chemical spill in Hopewell (industrial city) is likewise irrelevant to the discussion; a large molasses spill recently made global headlines for fish kills. Any connection of these sort of events to winterization presents an obvious logical falicy.
Please read the links below, including one from the USEPA.
http://www.practical-sailor.com/blog/-11059-1.html
http://water.epa.gov/scitech/wastetech/guide/airport/upload/2005_10_07_guide_airport_airport.pdf
Thinwater;
Every RV that is winterized uses what is referred to as RV non toxic anti freeze which is quite safe. Even those boats left in the water in cold climates when winterized uses the same as it is safe if discharged into the environment. The use of regular car antifreeze is very toxic and harmful if discharged into the water or even used in the fresh water lines.
First, I am not a chemist and there are many different compounds used in every product with different chemicals that are tested by the FDA and other sources before being allowed on the market. Their labels are very specific as to use and care.
As for all the parts used in RV's many of which can be found on boats, the RV non toxic antifreeze has never really been an issue on detoriation of those parts which many are replaced due to age/misuse/improper manufacturing and so on.
Therefore, I would never suggest the introduction of regular toxic antifreeze into any system other than the engine for internal cooling. I err on the side of safety and I think most will agree.
As for Hopewell, VA oh yes that was a big stink and it was international news. The state water control board of Virginia is very well attuned to that issue.
dave condon
