H25 running rigging length
18
Hunter 25 Lake Dillon, Colorado
How much running rigging do I need for a 77 Hunter 25? Any recommendations as to a good brand and a vendor to purchase it from? Thanks
Aug 25, 2006
27
Hunter 30 Somewhere
Running rigging lengths
The length depends on a couple of things. Standard factory mast or was it replaced at some point (and maybe taller/shorter), and do you want the lines run aft or not. Check the chandlery here. You select your model, and then options. You can go through the running rigging selection without actually ordering to get an ideal or the lengths, and if you like the price you can order and be all set.
jack42
Apr 9, 2007
5
-Hunter -25 Neenah, WI.
running rigging
Check with Sobstad, they helped me when purchashning new sails.
