H25 Deck Step
68
Hunter 25 Chicago
I would like to remove this and add a fresh piece of wood. I have a very small leak up there that drips down into the lav area, and it is coming from the wire plugs I am 99% sure. I see the first two bolts running down, one with a ground on the ceiling of the lav, but where are the other two? Will they be accessible once I get the wall / bulkhead off? Once I get access to them, how hard is it to replace this piece? I want to make it a tad wider up top to give the plugs a little more room and properly seal them and make more room for an additional plug or two I am going to run (spreader bar lights, move VHF antenna up, & move GPS antenna up).
Thanks.
