H240 water tank leak/electric pump
Brian
This is for those tired of yanking on that stock manual pump faucet on the 240. 1. First, I recently found a failure in the tube to tank connection which resulted in a very wet tank locker and bilge. I managed to dig the tank out, inspect and dry everything out and rework the connection with some sealing goop and retightened all the clamps. May want to make sure all the water line and bilge/drain lines are properly torqued on your boats as I found several other loose connections. 2. While I was in there yanking everything out I installed a 12v Whale SUPER INLINE 99 CENTRIFUGAL PUMP from Defender and mounted it in the small locker adjacent to the tank locker. It is switched via a rocker switch mounted next to the stock sink faucet. By the way, this pump is NON-self priming, so it works real well with the manual stock faucet, in that you can prime it with the manual faucet if the line goes dry, then once primed the Whale pump takes over. Works great and now I'll actually use my sink for something other than a locker. I already checked and the Whale has zero priming capability, so don't attempt using this pump if you have no primer faucet for some reason. Brian
